4th gen ECU pinout?
turbo6
Car: '05 350Z Turbo, '98 SC300 9.3@156, '99 SC400, '02 Police Interceptor
I am looking for a pinout of the ecu harness on my 95 maxima.. anyone have access to what each number on the ecu represents? Specifically I need to know where the coil pack wires are (6 ignition wires) and injectors?
I am familiar with this one.. but need a little more:
NISTECH
oh I want to say it is 24,25,31,32,42,and 43 but I am not 100% sure on that.
NISTECH
Hal an easy way to tell is this, on your coils 2 of the wires will be the same color on every coil but 1 wire will be a different color at the ecm if you find those six wires grouped together those are you coil wires, on your injectors one wire will be the same color on every injector but one will be different on every injector that is the ground signal form the ecm, if you go to the ecm and you find a group of wires on the connector all around each other that match the one different color on the injector that is your injector wire at the ecm.
turbo6
NISTECH: lovely, great idea! thanks
turbo6
IGNITION: 1,2,3,7,8,9
