bentvalves »
https://forums.nicoclub.com/bentvalves-u46428.html
Tue Aug 07, 2007 3:33 am
Hi fellas,
Got my car back together and finally time to map it after all these years! I have tomei 256 cams, vg30afm, exhaust, big intercooler, port/polish, 20 over forged pistons, power fc commander.
Today we started mapping the car on the street, and seem to be having an issue with AFM being maxxed, at a mere 15 psi. Tuner reckons that at 22 psi on an sr20 is when you would start to get to the outer cells during map trace (bit over my head bear with me)
So tommorow we try a borrowed AFM, and go from there.
My main question though, is the fact that my car seems to be coming into boost a bit late. I see full boost prolly between 3500-4000rpm and I have an AVCR to fine tune controlability.
Please folks steer me in the right direction, Im almost positive my timing belt was installed properly, double/triple checked. But what else would cause boost to come in late? Im almost forced to believe that perhaps timing is out a tooth?
people on sxoc say 3500-4k rpm for this turbo sounds about right........that to me sounds crazy though.
what do you guys thinks?
Greg
