4in exhaust.....
MOB240
Car: 1995 nissan 240sx
does anyone know of a good exhaust system that is 4in for an rb25? is 3in and 4in exhaust even that big of a performance increase? thanks
Shocker
Car: 89 240sxHB rb26/30
Any 4 inch will need to be custom, as far as I know no company makes any for a 240sx, unless your plan to make 500whp + 4 inch will be overkill.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
for the price and hassel of finding a 4in you are better off fab'n up ur own. The size differnce really depends on ur turbo setup. What turbo do you plan on using?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
More than overkill. 4 inch on a car that does not make extreme horsepower will rob performance. Exhaust gases flow just like every other fluid. A medium has to struck between maintaining the proper exhaust gas pressure so the engine doesn't have to physically push the air out, and have an exhaust that is too small and causes backpressure. An overly large exhaust decreases the velocity of the exhaust gases and can create backpressure just like an exhaust that is too small.
MOB240
i'm goin with the gt3076r and i'm shotting for 400-450hp range..im swapping an rb25 into my car this summer so i'm just gettin my parts list made up lol
redtop91
Ok. 4 inch is overkill IMO.
MOB240
yea i'll just go with the brm 3in exhaust lol
jobestudios
Car: (N/A)
with 3 inch you will also run less risk of scraping the hell out of your exhaust.
Logan76
Car: Junk
Ryon, I agree to dissagree, 4inch cant hurt, it goes on the same principle as Open DP, you will gain spool up time because you need no backpressure in a turbo car.
redtop91
Negative. An open DP is straight from the motor out. The exhaust pulses are sufficient to move the gases the foot or so to exit the DP. An exhaust has length which means the pulses have to move that same exhaust gas further, thus requiring a harder push which equals backpressure.
wawazat8402
Car: 89 Sil80- RB25DET
My plan for the new turbo is 3.5" to a 3.5" e-cutout then 3 inch from there to a couple of mufflers.
BTW, this is for a custom 62-1 that will hopefully be on this summer. Just waiting on EMS right now.
Logan76
Car: Junk
ahh you are correct, thats why a 3" exhaust keeps the exhaust gasses hotter and moving faster inside the exhaust, also why they escape faster, but you will gain spool up between shifts, but 4in is large, if your worried go with 3.5inch.
redtop91
LOL exhausts are one of the few things I know about simply due to my fluid dynamics class. The overly large exhaust theory can be demonstrated by buying a milkshake. You ever notice why they don't give you the regular straws for drinking the shake? Because it requires more energy to move the fluid through the straw. Likewise they don't give you a straw a foot in diameter because it will be equally difficult.
Shocker
for this matter I follow supra tactics, after all they seem to be making nice numbers.
BoostFab
Car: S13cp, S13fb, S14z
size matters, but be practical. boosted cars are different, you want less back pressure after the turbo. anything after the turbo, the larger and smoother the flow the better, of course fitments is a concern. anything larger than 3" must be custom built.i will be building a 4" down pipe with dual 3" straight back, just to keep cost down low.
redtop91
Once again incorrect. Overly large exhausts hinder performance. For most people's power levels 3-3.5 will suffice. You can have a too large exhaust. It can hurt performance.
BoostFab
redtop91 wrote:Once again incorrect. Overly large exhausts hinder performance.
that's a myth my friend. these claims are applied to NA cars, not boosted car. take it to the dyno and you'll see.
ofcourse you can't fit a 5" down pipe in our car. there's a reason why a 6" straight dump in front for drag cars.
redtop91
redtop91 wrote:The overly large exhaust theory can be demonstrated by buying a milkshake. You ever notice why they don't give you the regular straws for drinking the shake? Because it requires more energy to move the fluid through the straw. Likewise they don't give you a straw a foot in diameter because it will be equally difficult.
Are you disputing this?
Joe
BoostsFed wrote:that's a myth my friend. these claims are applied to NA cars, not boosted car. take it to the dyno and you'll see.
i disagree
volume and velocity are 2 different things. an exhaust too big will have the volume but not the velocity to let it escape efficiently.
BoostFab
about the shake?! or about fitting a foot diameter downpipe?!?
redtop91
Same theory just simplified. Don't be immature and avoid the discussion at hand.
BoostFab
seriously, I believe on a turbocharged engine once you have a well tuned(high flowing) manifold you can go as big as you can possibly fit downpipe + exaust, taking your power goal in to consideration. an average joe w/ 300hp a 3" is just more than enough, it's a different story if you're putting down twice that number.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
I'm not getting into this flame-war, but something to consider. I got my 3" Blitz exhaust from a friend with a KA-T after he purchased a Du-Luck 3.5" and saw gains from it. I know he had to wait over a month to get it here, but he said it was worth it. (Plus he is a certified Mechanical Engineer and I trust his judgment.)
Chaos the Xile
Car: 1974 Datsun 260Z
Apexi GT-Spec Exhaust. 3.75" The largest exhaust you can buy I believe at the current time SOUNDS BAD *** TOO!
002-M-P
Car: Z33-RB26 IP
When in doubt, go by Corky Bell's quote "The best exhaust for a turbo, is no exhaust at all"
But just incase that doesn't do it for you, I found this on another forum...
anotherforum wrote:N/A cars: as most of you know, the design of turbo exhaust systems runs counter to exhaust design for n/a vehicles. N/A cars utilize exhaust velocity (not backpressure) in the collector to aid in scavenging other cylinders during the blowdown process. It just so happens that to get the appropriate velocity, you have to squeeze down the diameter of the discharge of the collector (aka the exhaust), which also induces backpressure. The backpressure is an undesirable byproduct of the desire to have a certain degree of exhaust velocity. Go too big, and you lose velocity and its associated beneficial scavenging effect. Too small and the backpressure skyrockets, more than offsetting any gain made by scavenging. There is a happy medium here.
for turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end.
downstream of the turbine (aka the turboback exhaust), you want the least backpressure possible. No ifs, ands, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turboback exhausts is valid. here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure.
again, less pressure downstream of the turbine is goodness. This approach minimizes the time-to-boost (maximizes boost response) and will improve engine VE throughout the rev range.
as for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.”
"as for the geometry of the exhaust at the turbine discharge, the most optimal configuration would be a gradual increase in diameter from the turbine's exducer to the desired exhaust diameter-- via a straight conical diffuser of 7-12° included angle (to minimize flow separation and skin friction losses) mounted right at the turbine discharge. Many turbochargers found in diesels have this diffuser section cast right into the turbine housing. A hyperbolic increase in diameter (like a trumpet snorkus) is theoretically ideal but I've never seen one in use (and doubt it would be measurably superior to a straight diffuser). The wastegate flow would be via a completely divorced (separated from the main turbine discharge flow) dumptube. Due the realities of packaging, cost, and emissions compliance this config is rarely possible on street cars. You will, however, see this type of layout on dedicated race vehicles.
a large "bellmouth" config which combines the turbine discharge and wastegate flow (without a divider between the two) is certainly better than the compromised stock routing, but not as effective as the above.
if an integrated exhaust (non-divorced wastegate flow) is required, keep the wastegate flow separate from the main turbine discharge flow for ~12-18" before reintroducing it. This will minimize the impact on turbine efficiency-- the introduction of the wastegate flow disrupts the flow field of the main turbine discharge flow.
necking the exhaust down to a suboptimal diameter is never a good idea, but if it is necessary, doing it further downstream is better than doing it close to the turbine discharge since it will minimize the exhaust's contribution to backpressure. Better yet: don't neck down the exhaust at all.
also, the temperature of the exhaust coming out of a cat is higher than the inlet temperature, due to the exothermic oxidation of unburned hydrocarbons in the cat. So the total heat loss (and density increase) of the gases as it travels down the exhaust is not as prominent as it seems.
another thing to keep in mind is that cylinder scavenging takes place where the flows from separate cylinders merge (i.e. in the collector). There is no such thing as cylinder scavenging downstream of the turbine, and hence, no reason to desire high exhaust velocity here. You will only introduce unwanted backpressure.
Other things you can do (in addition to choosing an appropriate diameter) to minimize exhaust backpressure in a turboback exhaust are: avoid crush-bent tubes (use mandrel bends); avoid tight-radius turns (keep it as straight as possible); avoid step changes in diameter; avoid "cheated" radii (cuts that are non-perpendicular); use a high flow cat; use a straight-thru perforated core muffler... etc
comparing the two bellmouth designs, I've never seen either one so I can only speculate. But based on your description, and assuming neither of them have a divider wall/tongue between the turbine discharge and wg dump, I'd venture that you'd be hard pressed to measure a difference between the two. The more gradual taper intuitively appears more desirable, but it's likely that it's beyond the point of diminishing returns. Either one sounds like it will improve the wastegate's discharge coefficient over the stock config, which will constitute the single biggest difference. This will allow more control over boost creep. Neither is as optimal as the divorced wastegate flow arrangement, however.
there's more to it, though-- if a larger bellmouth is excessively large right at the turbine discharge (a large step diameter increase), there will be an unrecoverable dump loss that will contribute to backpressure. This is why a gradual increase in diameter, like the conical diffuser mentioned earlier, is desirable at the turbine discharge.
as for primary lengths on turbo headers, it is advantageous to use equal-length primaries to time the arrival of the pulses at the turbine equally and to keep cylinder reversion balanced across all cylinders. This will improve boost response and the engine's VE. Equal-length is often difficult to achieve due to tight packaging, fabrication difficulty, and the desire to have runners of the shortest possible length.”
"here's a worked example (simplified) of how larger exhausts help turbo cars:
say you have a turbo operating at a turbine pressure ratio (aka expansion ratio) of 1.8:1. You have a small turboback exhaust that contributes, say, 10 psig backpressure at the turbine discharge at redline. The total backpressure seen by the engine (upstream of the turbine) in this case is:
(14.5 +10)*1.8 = 44.1 psia = 29.6 psig total backpressure
so here, the turbine contributed 19.6 psig of backpressure to the total.
now you slap on a proper low-backpressure, big turboback exhaust. Same turbo, same boost, etc. You measure 3 psig backpressure at the turbine discharge. In this case the engine sees just 17 psig total backpressure! And the turbine's contribution to the total backpressure is reduced to 14 psig (note: this is 5.6 psig lower than its contribution in the "small turboback" case).
so in the end, the engine saw a reduction in backpressure of 12.6 psig when you swapped turbobacks in this example. This reduction in backpressure is where all the engine's VE gains come from.
*this is why larger exhausts make such big gains on nearly all stock turbo cars*-- the turbine compounds the downstream backpressure via its expansion ratio. This is also why bigger turbos make more power at a given boost level-- they improve engine VE by operating at lower turbine expansion ratios for a given boost level.
A=as you can see, the backpressure penalty of running a too-small exhaust (like 2.5" for 350 hp) will vary depending on the match. At a given power level, a smaller turbo will generally be operating at a higher turbine pressure ratio and so will actually make the engine more sensitive to the backpressure downstream of the turbine than a larger turbine/turbo would. As for output temperatures, I'm not sure I understand the question. Are you referring to compressor outlet temperatures?
the advantage to the bellmouth setup from the wg's perspective is that it allows a less torturous path for the bypassed gases to escape. This makes it more effective in bypassing gases for a given pressure differential and wg valve position. Think of it as improving the VE of the wastegate. If you have a very compromised wg discharge routing, under some conditions the wg may not be able bypass enough flow to control boost, even when wide open. So the gases go through the turbine instead of the wg, and boost creeps up.
the downside to a bellmouth is that the wg flow still dumps right into the turbine discharge. A divider wall would be beneficial here. And, as mentioned earlier, if you go too big on the bellmouth and the turbine discharge flow sees a rapid area change (regardless of whether the wg flow is being introduced there or not), you will incur a backpressure penalty right at the site of the step. This is why you want gradual area changes in your exhaust.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
ask this questuion when you have a potential 500 hp mota in yo whip
matafied
Car: 1989 240 rb25det 1992 240 rb25det
AHHH u beat me to it!!! Corky bell is the man LOL
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
LOL Corky Bell is so 1990! I'm just joking, it is a good read.
Just because you have taken a fluid dynamics class doesn't mean you are an expert in air piping design. Let me guess that you are a typical engineering student (mechanical? junior?), so green that he doesn't need to dress up for St. Paddy's Day? haha jk guy. I can give you a hard time because I was one of those "know it alls" too.
There are many other important factors to look at in an exhaust than diameter. Yeah the diameter determines the velocity through the pipe runs, but the bends, inlets, outlets, and connection irregularities can result in measurable head loss. If you want a larger exhaust, go for it. It isn't going to hurt performance on a turbocharged motor unless your fabrication job introduces turbulence into the flow and results in significant head loss. Yes, it will have to be custom. Otherwise, buy an Apexi GT Spec if you can afford the shipping costs (9' long box). It steps up from 3" to 3.75" at the muffler. Refer to my video on YouTube.com for the sound clip.
eh?
002-M-P wrote:Remember, a turbine operates via a pressure ratio
I'm sure they didn't teach that in FD class..
rbforsale
Car: '92 Nissan 240SX S13 vert ka-s
3 inches is fine for single turbo setup,most supras that have 4 inch exhaust that moves in to a 6 inch opening have a twin set up, just throwin that out there
