CFRage wrote:I do mostly city stop and go driving. I have the 4AT transmission and usualy leave O/D on, however my top speed 80% of the time is about 45 MPH and I've noticed that my RPM rarely gets over 1800 while cruising. I have about 1500 miles on the car so far and up to this point my MPG has been horrible. I'm averaging about 21 to 24MPG. Would running with O/D off help this? I've checked tire pressure, etc etc. Low fuel light comes on with about 230 - 260 miles on a tank. Thanks!
I have a 4AT and do city/hwy driving. I leave the OD on most of the time and I get 33-35 MPG about every week. I only turn it off when I am really trying to get out in traffic and need the extra pick-up.
At 1500 miles, you are still not at the optimal MPG break in point but you should be getting better than 21-24. Have you considered your driving style or route? Lots of stoplights will drag it down as will fast take offs. I have noticed that most drivers take off way too fast (gun it at the green light) and this is a very big gas waster. I read that you should try to pretend there is an egg under the pedal, and as lame as that sounds, I have started doing that only to see 90% of the cars wizz past me. And then sit there as I roll by when the light has turned green.
Also, I live in VA as well but down in tidewater where it is FLAT. I know Richmond is hilly, so this may be something that may be affecting your MPG.
