frankoV »
https://forums.nicoclub.com/frankov-u85137.html
Wed Jul 02, 2008 3:06 pm
They are telling you to do a Maintenance Package 3, which is lots of checks and little work; in Ottawa $210 plus taxes. A lot of the checks you can do yourself if you are a little knowledgeable. You are right -- they need to make their money. But $200 for a visual inspection is a bit much imo:
Inspect Air Filter*(S2)Battery fluid level Brake linings, drums, pads, discs*(S1)**Clutch and hydraulic fluid levels* Condition of exhaust system and mountings Coolant fluid level and radiator hoses Cooling fluid density*(S5)Dust covers & drive shaft boots Fluid levels and condition of brake lines & hoses Fuel lines, connections, fuel tank vapour vent, system hoses, fuel tank bands* and fuel tank cap gasket High tension wires Horn, wipers and all exterior lights Lubricate locks, latches and hinges Power steering fluid level Steering components Suspension components**Tire condition and pressure
AdjustDrive belts and inspect condition
ReplaceEngine oil and oil filter
RotateTires
PLUSInspect distributor cap & rotorInspect transmission fluids (except CVT)
Road test vehicle.
Supplement
If applicable, replace PCV valve/filter [read: if they can get away with it]If vehicle is equipped with a Cabin Air filter, replacement is recommended at 12 months/24,000 km (obtain estimate from service)
Replace fuel filter[if they can get away with it]
Replace coolant[again, if they can]
