the forsaken wrote:but then what is the stock injector size of the ca18det? and how do i retune the ecu.I got an adjustable FPR and afr. So than i'll need a z32 mafs? and what more?????
-Stock injector size is 370cc. Please search and read the FAQ.-To retune the ECU you have to de-solder the stock chip, solder in a new socket, build/buy a romulator, download the software to change the settings in the rom, buy new rom chips, and burn the info onto them and install the new chip. It's way more complicated than what I just explained and if you have to ask how, you have a lot of research to do. Please search and read the FAQ.-After that you will need to a lot of studying and reading so that you don't blow your stuff up. Please search and read the FAQ.
the forsaken wrote:and do i need to modify anything to install the z32 mafs.????and how would i tune it considering the other things i already have?
-You will have to have the z32 mafs and the plug to go with it. Then you will have to splice the Z32 plug onto your harness. Please search and read the FAQ. -To tune it you will need to either re-tune the stock ecu as described as above, or install a standalone engine management, which would negate most of the items you purchased to date. Both options appear to be above your current capabilities. I would highly recommend spending some money and paying someone to do the ECU work for you and then take the car with the SAFC installed to a shop and have it fine tuned on a dyno. Please search and read the FAQ.
