450ZX Wiring
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
vg30de93
Car: 93 300zx 2+2
well i thought i had figured this writeup out: vh45de-to-z32-complete-wiring-integrati ... 35689.html but i cant for the life of me. The guy used a 94+ wiring harness and i have a (90-92) i try to match up the connector numbers he list bust the letters, numbers, and locations arnt matching up the best. im affraid to go just chopping away. and i use the 300zx online service manual and the numbers/connectors dont match up like he says either. can some one point me to other write ups so i can piece this together and move on to cranking her up. WES, T45, any insight guys would be awsome
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
I used that guide with a early VH and Z32 harness. The pinouts are the same for the VH ECU, you will have to follow the wires for the Z32 one youself as it depends on NA/TT, 5 speed/auto, LHD/RHD.
The document that Nick put together will give you a good insight into what has to be done and after that you should be able to work it out pretty easily. I haven't seen any other writeups, but it is all pretty much common sense once you get into it.
Speedo to speedo
Tacho to tacho
Consult to consult
Power to Power
etc.
Not too bad.
Return to “VH45DE / VK45DE / VK56DE Forum”
