T45 »
https://forums.nicoclub.com/t45-u41813.html
Mon Jun 02, 2008 1:20 am
What I was referring to was the mani's hitting the crossmember on the very bottom, near the forward most cyl's.
After my engine was in I cut off the cats, shrouding and then jacked the engine up a bit and they slid right into place. After lowering the engine back down they hit on the bottom along the xmember. If you look at the xmember it has a little hump there too.
I took my torch, heated up that little bulge on the xmember and flattened it out with a bfh. Then checked clearances again. I needed more so I marked the headers, took them out and heated them up, bfh'd the BOTTOM of them to gain some extra clearance. I didn't "go to town", just flattened it out a little bit to give some room. 1/8" flatter on the bottom gives you a lot more room to work with.
I didn't have to modify them whatsoever to get them to fit in between the frame rails side to side, they fit fine, just tight.
