450z fuel ?'s
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
MRJERRY300ZX
Car: 92' 300zx soon a "Z45"
will there be any problems of fuel starvation car is a 92 300zx swapped in a Vh45 and I'm only asking b/c I went from 3.0 to 4.5 I still have the stock fuel pump can you please point me in the right direction thanx
Q45tech
The twin turbo pump and Q45 pump are the same, the 300zx NA is about a third less capacity.
The 4.5 rail , regulator and pulse damper are designed to be feed from the Q45 pump with the 3 speed voltage control [FPCU].
qsiguy
Car: 1994 Infiniti Q45 Turbo
You going turbo with that VH or NA? You should be fine even if you go turbo up to about 8-10 PSI. I need to check my fuel pressure at full boost but my AFR's are good up to 8 psi, haven't tested much above that yet but I have ran at 9 psi for a short time with no obvious trouble.
If you are staying NA you are in great shape.
craigztoyz
Car: lots of unique hot rods, and customs, with modern engines, and a good truck to pull the trailer.
MRJERRY300ZX wrote:will there be any problems of fuel starvation car is a 92 300zx swapped in a Vh45 and I'm only asking b/c I went from 3.0 to 4.5 I still have the stock fuel pump can you please point me in the right direction thanx
If your car was T then you are fine, if it was NA then you need to swap.
So you are in H town? Nick is over there in the Smog too. Ha Ha Ha
I'm in Austin, SO there are about to be 3 of us Z45 guys in the hill country, interesting............
SSDwellah
Car: '90 Z32 Coupe w/ VH45DE + 5-speed (FOR SALE)
'06 Infiniti G35 Coupe 6MT
'08 Frontier 4x4 SE KC
My setup was originally a NA Z32 and I opted for the walbro 255, but I heard rumors that the Z32TT/VH45DE unit is the same as the walbro. I find that hard to believe because they didn't look the same, and I have seen benchmarks that the walbro 255 does not ultimately flow as well as the Z32TT pump in the high HP ranges but I can't find that thread again... I'll keep looking. In any event, the walbro was like $200-300 cheaper than what the stealership quotes for a brand new in box TT fuel pump, and about $200 cheaper than the cheapest sale you can get an honest to God Z32TT new pump for.
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
Z32TT pump and 255 Walbro are definately different. I believe the standard Z pump is a Bosch unit.
The standard Z32TT pump is one of the higest flowing in tank pumps available.
Q45tech
255 lph is 67 gallons per hour or 480 pounds per hour enough to create 900 HP.
The rub is how you regulate the pressure and what it is as the flow starts to decline when you exceed 43.4 psi.
Good engineering practice to assure 70k+ life that the pump capacity is 3 times larger than PEAK DEMAND..........thus a 300 HP engine is supplied with a 900 HP capable pump.
Same with the regulation system having the ability to divert 2/3 of the flow demand back to tank allows a lot of wear and tear to occur before the inlet flow decreases enough to stop ACCURATE REGULATION.
Use cheap pumps if you don't mind replacing them frequently.
T45
Car: King Kong powered Z32
Even this used one will outperform a new walbro in the long run.
http://cgi.ebay.com/ebaymotors...02951&
Return to “VH45DE / VK45DE / VK56DE Forum”
