450sx Brake issues
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
DriftDanimal
Car: S13 Vh45
Impreza WRX
So im running into some brake issues with my swap. Running stock brakes, stock BMC, and 91 Sentra Booster.
Pedal is hard when car is off, drops when car is on. Have bled the brakes and still the same, leads me to believe that the BMC is possibly bad or not getting good pressure from running this booster.
What setup are you running? How quick is pedal engaging the brakes?
Thanks,
Dan
heres the b**** giving me trouble..
300ZXttZMAN
You might see better luck in the 240sx forum you should try that
300ZXttZMAN
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Is the brake booster new or used?
I ran the same set-up with now issues.
DriftDanimal
Car: S13 Vh45
Impreza WRX
Gotcha, thats all I needed to know. The Booster is brand new, that means Im going to swap the BMC now.
I didnt post this in the 240sx area because most people have no need to run this brake setup.
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
I would assume your BMC is bad being that it's firm when off so the booster is fine.
JSimpson21
Car: '97 SRVE
'90 450sx
I run the old sentra booster from a junkyard and my otherwise stock brakes are pretty awesome. Probably BMC or bleed it with the car running. It makes a difference.
Return to “VH45DE / VK45DE / VK56DE Forum”
