x2 you will probably be money ahead (and actually get to your goal) if you spend whatever cash is needed on making the 3271 work.gawdzilla wrote:there's some work involved to fit 26 twins on a 25. if you want to do it right you'll probably spend an extra 500 bucks minimum just to fit them on. adapter flange, manifolds, lines, etc. after that, you'll find out the stock 26 twins cant get to 450 whp anyway. i'd go with that other turbo you have.
