450cc injectors in! Just a few pics
slo325i
Car: 87 327i, 92 240sx
Thanks for all your help guys. The ca's running top notch
dhen
Car: MGA w/ CA18DET
Did you run into any issues with this? I'm getting ready to do the same soon.
Darian
bentvalves
Car: 89 Silvia K's
running the exhaust side valve cover breather tube into the intake cam covers breather which is T'd into the PCV valve which is shut under boost is pressurizing your crankcase under boost.
run that line either to a catch can/bottle or pre inlet i.e. oem. dont wait do it meow.
slo325i
ks13 wrote:running the exhaust side valve cover breather tube into the intake cam covers breather which is T'd into the PCV valve which is shut under boost is pressurizing your crankcase under boost.
Oh, oops!!
Thanks for letting me know that. I didn't know what to do with that side and I just ran it like so. I'll work on it asap. Thanks!
slo325i
dhen wrote:Did you run into any issues with this? I'm getting ready to do the same soon.
Darian
Well i've only had it at idle and up to 3k rpm so far. No problems yet. Although not accurate at all, my narrow band gauge has read stoich thus far. I don't have the proper chip for it yet so I'm not going to push it. But I have to tell you that it's running very smoooth.
I'm also running the exhaust cam into the intake side which I think adds to the smoothness.
