gdz1la wrote:how much is require to machine of the housings, and whats the best way to line them up before welding/screwing? is there enought room for a few bolts from the v8 'flange' into the vg box?how thick is johns adaptor and the spacer? if even the box must sit flush?
cheers guys ive been slack, building a s13 rb26dett and a c35 laurel rb30det in between the s15 450sx t88 project lol
Lol once you've done the V8 you'll never go back to ***** RB engines again
I've attached a crudely drawn paint image showing what dimensions you need to establish.
The red line through the spigot shaft indicates the desired position of where the outside face of the spigot bearing (the one you will use, not the auto converter pilot bush) will be once the assembly is bolted together as it should be. You need to determine this, based on how far in the spigot shaft can go, and where exactly you need your splines to be.
The leftmost dimension is arbitrarily drawn, but you need to determine the distance between the outside face of the spigot bearing and the mating face on the block where the sandwich plate goes. I can't remember now whether this sits proud of that face, or whether it is in fact under flush.
Then you need to decide where on each bellhousing you'd like to cut to achieve matching diameters, to make welding them together easy. You add these two dimensions together, and subtract the thickness of the sandwich plate. The formula SHOULD state 1 + 2 - T = X (T being sandwich plate thickness) but I forgot about it until posting.
You now have the desired cutting depth for your auto bellhousing. Put it on a mill and chop it up !
You're away !
Use a jack, or stack stuff under the gearbox to get it to the desired height, but measure the crap out of it constantly to ensure you have it lined up perfectly. Not really sure how this is done properly, if anyone has a better suggestion, I'm all ears !
