240Kuminachu »
https://forums.nicoclub.com/240kuminachu-u946.html
Mon Apr 25, 2005 4:58 pm
Yes you should build the bottom end if your wanting that much power.
It will last longer.If your going to do it, do it right. Enjuku put out like 560 at the wheels on a stock bottom end, doesnt mean yours will, how long will it last?Piece of mind.Ceramic coat them while your at it, it will help disapate heat, turbo motors make heat, heat will kill your motor.I recomend aries pistons, they come with rings. Go .40, to 87mm, helps out torque. Think about it, your more than doubleing the stock power of a 4-banger, its not made for it.
My buddy just blew his SR, he was 450 at the crank, forged bottom end. Due to octane, he melted the pistons, 425 seems to be about the limit on 92 octane.
I dont want to see you waste money on a motor that is pushed to close to its limits. Its better for the long run. YOu've been in this for a while, longer than alot of guys on here, you should know building the bottom end should not even cross your mind twice at that HP level.
Your better off, just do it.
