There arnt such problems, I have had my $350 stainless steel mani on my car for 8000 miles no problem, but I accept the fact that they are not indestructable like cast iron ones. I saw a AWD galant VR4 lay down over 400 horsepower, and he was using an aftermarket cast iron manifold simply because he didnt want any hassles with SS. We dont need an aftermarket cast iron manifold for the SR20 because the stock one can do the job.spanishricer wrote:I just can't comprehend why there seems to be such problems with aftermarket stainless manifolds cracking in the SR motor. Or is this a common problem shared by all turbocharged cars? Because I had an aftermarket stainless exhaust manifold on my Prelude for 4+ years, and I never had an issue with it. Is it the higher exhaust gas temperatures that cause the manifolds to have such a short life span?
Like others have mentioned, there are certain steps you can take to prolong the life of a stainless manifold.spanishricer wrote:I just can't comprehend why there seems to be such problems with aftermarket stainless manifolds cracking in the SR motor.
I don't know if your prelude was na, but most all Honda products use a donut gasket with a spring loaded flange to allow flex.spanishricer wrote:I just can't comprehend why there seems to be such problems with aftermarket stainless manifolds cracking in the SR motor. Or is this a common problem shared by all turbocharged cars? Because I had an aftermarket stainless exhaust manifold on my Prelude for 4+ years, and I never had an issue with it. Is it the higher exhaust gas temperatures that cause the manifolds to have such a short life span?
Not true. There are no flex points on the stock system. All solid flush bolt flanges.89 240hatch wrote:im sure the sr has a stock flexpipe in the exhuast
The .64 a/r GT2871 has been proven to make 370-380 whp on stock manifolds at 18-19 psi, so I'd feal that 20-21 psi would net you the magical 400 on the .64. This is very dependent on having the right mods though!namwons_240 wrote:Yes, u can make 400 hp on the 2871r on stock manifold but at what pressure, 25+psi which will cause even more back pressure in the manifold and start choking the turbo and engine. On one of scott enthralpy's threads about this they were building a 500hp car and gained 60hp!!! JUST from the exaust manifold alone before tuning to 500hp. So u dont need one but your engine will be alot happier with one, just get a quality one. The straighter, free flowing an engine is, the more power and efficiency your will get, thats why turbojet engines make so much power.
