4000+ rpm popping sound HELP!!
Reno
Car: 89 S13, boosted.. RAWR..
hey guys and gals.. and everyone in between
i have a wierd problem with my baby.
its making these wierd noises when i put it in netural and increase the rpm to about 4000+ - 6000 and its making a thubbing sound of some sort. its the engine. i know that much. umm its like the pistons are not getting gas??i really dont know.. i mean on the street its awsome.. sorta but when i test it out in netural it does that noise. maybe i can get a digi video camera and post the sound if that may help? thx.
Reno
i found out that its a possibilitythats its misfiring and i noticed injector #2 is very loud. its been loud for over a year so i dunoo.
slipnfall
Car: '06 D40
You might want to check for exhaust leaks: I had one on the collector-to-cat that would only leak at certain RPM's(it would pop, as you described). In this case look for discoloration around the flanges/gasket.
Also I don't advise revving your engine in neutral like that too often... not good on the engine.
Reno
oh man i have alot! i got like 3-7 holes on my exhaust pipe alone.. no cat and i just removed the heat shield.. i noticed the sounds after i removed the heatshield... thanks
what would be the besy way to get the 3in exhaust from? i was thinking maybe the mufflerman 3in pipe after cat delete dunno. i also need a 3in muffler any idea where i can get one that big??
NISTECH
Goto the 240 forums and look up the BRM stuff. I have seen a nd heard it first hand. I like it. perfect sound at idle, not to loud and sounds good at cruise speeds. If you dont like noise I recommend getting the resonator. Other wise its gonna sound pretty close to a stock car at the races[just the way I like it]
Reno
i dont think its the exhaust.... my engine vibrates violently when making the noise... sounds like a misfire.. maybe bad injectors or maybe running lean?
slipnfall
Car: '06 D40
What do your spark plugs looks like(and how long ago were they replaced)? Check the easy stuff first for signs of other problems.
Reno
plugs were replaced like almost 2 months ago, dunno what they look like
180fan
Car: 89 fastback
injector plugs i'm guessing.
Reno
bump
