evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Feb 15, 2008 8:56 pm
uh...."Datsun' with a"U"
anyhow, depending on the level of build and intended use the cahssis may or may not need reinforcement, the stock sbc 400's depending on emissions and heads can be pretty low hp, most street built 400's still fall short of 400 chp, which should be ok in most datsun cahssis unless you plan to race it, in which case the motor has little to do with the stiffening you want to do, how you stiffen fro drag racing is different from how you stiffen for road racing
as for shich chassis to use, what you can find thats not rusted will help dictate taht choice, unfortunately the datsuns seem to get eaten up with trust, an 810 would be a sweet little sleeper but they are kinda hard to fine, the dimes and b210's are the smallest lightest options short of the convertible srl's and spl's, the S30 and S130 swaps are of course quite popular with the advantage of having lots of documented swaps and plenty of chassis aftermarket still available, the s130 and z31 both offer better chassis than earlier cars and things like 4 wheel disk brakes and they also come with power steering which can be an issue for some poeple, the chassis you choose will determine how much work the swap is, in the s30 and s130 it's as silmple as cutting a couple of setback plates and spacers
