ttvines »
https://forums.nicoclub.com/ttvines-u73889.html
Thu Nov 08, 2007 7:19 pm
Hey I have a 92 240sx with a ca18det swapped. But I have a problem. When i first turn the car on it will start right away but it will idle at 400 rpm and it wont rev, it will shake violently unless i go really really easy tapping on the throttle, has no power. When it warms up the idle slowly rises to 850 rpm and revs good and sounds good and drives. So i check my error codes, I get Ignition Signal, Crank Angle sensor and Detonation Sensor error codes. I'v been reading the FSM but i dont know where to start.
thanks
Thomas
