mistamacadamian »
https://forums.nicoclub.com/mistamacadamian-u57651.html
Mon Jul 07, 2008 7:53 pm
another update, except with problems. went to the track mixed some 93 with 110. boost set to 15 and on the way it seemed to have stuttering problems, bad. ran it once and called it a day b/c it was stuttering bad and acceleration wise i got raped by a stock SR who was on 10psi, i trapped a 105.... timing was set to 15 which is stock. boost leaked test and found a little leak, nothing too significant and was plugged. cleaned the MAF, changed the spark plugs and gapped to .025. it still stutters while accelerating but if you floor it, it will boost and not stutter, it will not hold in any RPM's while cruising and stutter. vaccume fluctuates from 22-15 at idle and will idle like crap. im not sure whats the deal, ill be takign the valve cover off this weekend to see whats up. ITS not tuned for the cams, I had e-mailed enthalopy(scott) and he had said for 264's i would be good for the tune i have. tial bov is going on this week. and the knock off type s i had is leaking a little at idle, but cant be the only problem for the idle. any input is appreciated.
