Hello all, I have an 86 720 4X4 I've been restoring and have it just about all done except the paint. I've never dealt with 4 x 4's before, so I'm a little stumped once again. It runs and drives great, but when I decelarate I'm getting a heavy rumble or vibration from the drive train. It will also show up when I hit about 50MPH. I checked the drive shafts and put new universals on the rear one. The front wheel drive drive shaft has a little play in the expansion splines, but not but a nudge. Any Ideas what could be doing this? I know the transmission is fine because it came out of my '85, which ran and drove when I pulled the motor and trans. I checked the xfer case before reinstalling it and it seemed to be in pretty good shape. It didn't seem to have any slop or play. I am going to replace the front wheel bearings next. If it winds up being the drive shafts (expansion splines worn), does anyone know where I can get new ones for that truck. Anything I get from a junk yard would be in the same condition I would assume.
Thanks in advance for all of your help!!!
