The factory service manual says to check the ATP switch circuit.
Page TF-112 of the FSM has instructions on doing so.
Also ensure the fluid level is correct - remove the fill plug and stick your finger in. If the fluid level is at the bottom of your finger on a flat surface, the level is OK. If the fluid has never been changed, do a drain & fill at this time.
