Shift__BODOM »
https://forums.nicoclub.com/shift-bodom-u20648.html
Tue Jun 07, 2005 1:40 pm
i dont know which wires exactly are for the hazards, but the power is a 12 volt power source (either find one in the dash, or just run a wire through the passenger side firewall grommet [look under the hood by the intake] to the positive battery terminal) ground is, well...a ground. splice a wire into another ground, or run a wire through that firewall grommet. load is going to be the wires that run out to the 4 blinkers. lemme pull my hazard switch and i'll post which wires you need to put into the load terminal.
i just put in a toggle switch 2 nights ago for my sleepy lights, so it's all fresh in my mind.
i'll be right back
