MasterOSkillio »
https://forums.nicoclub.com/masteroskillio-u140085.html
Fri Sep 14, 2012 1:40 pm
FR sports guy says he has done it, so I guess it works:
13:28:29 Operator Alan joined the chat
13:28:48 Alan: Yes you should be able to
13:29:04 Alan: However this advice is from personal experiences
13:29:17 Alan: It is not a gaurantee.
13:30:21 Visitor: I am sorry are you saying you did this personally and it worked?
13:31:17 Alan: Yes sir
13:32:12 Visitor: oh wow, ok , did you need a press to fit them on? or do they slide off?
13:33:38 Alan: They will take a little effort
13:34:12 Alan: I cannot vouch for the effectiveness on this though
13:34:41 Visitor: can I ask how long you have had you car set up like this?
13:35:03 Alan: I apologize I just have to make you aware that I am not 100% on this modification
13:35:14 Alan: I have done this on my previous car
13:35:35 Alan: It is just a ring that goes around the hub that sends signals for the ABS to work properly
13:36:28 Alan: I am just adding a disclaimer. I am not saying that this is the proper way to do this but I will try my best to assist you.
13:37:28 Visitor: right I wasnt sure if the non abs hub had a groove for the ring to fit.
13:38:23 Alan: From what I recall, there shouldn't be a groove
13:38:38 Alan: the ring would slip over the circumference of the base of the hub
13:39:04 Visitor: ok, thanks man, I appreciate it
13:39:13 Alan: Of course no problem
13:39:17 Alan: Good luck
13:39:21 Alan: Have a good day.
Thanks for the suggestion compactfean! !
