mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Sun Nov 25, 2007 12:24 pm
This doesn't happen all of the time but it does happen more times then not.You ask what happens. Well, I turn the key in the on position, then I tun it to the start position and hold it until the starter begins to run. Once in a while the starter will run as soon as I turn the key but most of the time when I turn it and hold it in the start position, it takes about 4 seconds before the starter runs and turns the engine over.
When I hold the key in the start position, everything is the same when it has the delay just as it is when it doesn't have the delay. Nothings seems different. I have tried jiggling the key while holding it in the start position but nothing changes. I still wait 3 to 4 seconds regardless if I am jiggling it or not.
Modified by mattd1979 at 8:32 PM 11/25/2007
