4-Point...
All things Altima Coupe.
tuffmag
Car: 2008 Winter Frost, Altima coupe 3.5SE CVT, Premium, Technology Package
Anyone out here can tell me if this is the truth! I went to 2 different Nissan Dealers about the alignment spec’s. I was told they are the same for the Coupe as for the sedan.Is this true?
GryStrm
Car: 2008 Altima Coupe 3.5
...ok ready for this....DEALERS KNOW NOTHING....they have no clue....they will answer you in anyway they can...even if its wrong...my dealer argued with me that the 3.5 cpe came standard with an 18" wheel...
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
SEDAN Alignment Specs
COUPE Alignment Specs
looks like the sedan and coupe are exactly the same
tuffmag
yep, yep...sound like Adidas2go comes thru again
thanks
but at some point down the road could it change? is not the wheel base length different from the sedan? Could it be Nissan states the specks are so close that there is no need to change?
Either way, I had the stock specs applied.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
There is no real need to change specs based on wheel base. The biggest dictator of alignment specs is fwd or rwd, other than that they tend to be very similar. If you want something a little "sportier" throw a little bit of toe out on the front and you'll be all set.
tuffmag
Sportier is what it's all about. I know it is a drivers point of view, but what would be some good numbers? Are we speaking Neg numbers on the toe?
Guess I should put my mods on the page...but anyway Stillen SWB, EIBACH pro kit, so Guessing I am ready to make it a little more sporty..
BTW thank you "the Converted" for your answer
Modified by tuffmag at 9:33 AM 5/13/2008
stsxcrle
Adidas, FYI: if you hold ALT while taking a screenshot, it will only capture the open window, in this case you wouldn't see your taskbar.
tuffmag
stsxcrle wrote:Adidas, FYI: if you hold ALT while taking a screenshot, it will only capture the open window, in this case you wouldn't see your taskbar.
Yea! but we ALL enjoy seeing what he has open on his desktop
adidas2go
Thanks buddy I didnt know that. Its cool though. Nothing to increminating on here, other than tylers screen name haha
mcheddadi
Car: R8
Lol I just noticed you changed your custom tag. anything + god sounds soo sweet lool
adidas2go
eh, after seeing yours, it seems more fitting to the current scenarios I play in the a/c community
niztec
Car: 2008 AlTIMA COUPE
would of been funny if we saw something pornographic..
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
tuffmag wrote:Sportier is what it's all about. I know it is a drivers point of view, but what would be some good numbers? Are we speaking Neg numbers on the toe?
Typically I ran 1/32" to 1/16" of toe out on the front and 0 on the back of my cars.
It's a good compromise of handling response and tire wear. Any more and the car gets very darty on the highway and you eat right through tires.
