thrasherx89 wrote:1. i have the sides of the harness for the lap secured to the stock seat belt harness by a 800lb hook (like used for rock climbing) and i weigh 150 so thats good enough to handle 5.3 g's which i think is good enough but...should i upgrade to 1000lb just to be safe or is it good enough?
2. the shoulder straps i have in that lame mounting point under the rear seat mounts, and i hate it. now i hear that mounting to the c pillar bar is unsafe, but isnt that where the rear shoulder strap is mounted so im wondering why it isnt safe?
3. i was also considering mounting to the rear strut tower brace...i would put those climbing hooks on the bar (x4) and have the rear seat down and if i needed passenger i would just have the same hooks on the bottom of my seat mounts in case...one option
4. i was considering fabing something to mount similar to a harness bar but is less intrusive on rear passengers as i might have some sometimes. i was considering making a bar that mounts to where the stock front shoulder seat belt motor goes as i removed mine...and maybe having another support bar? problem would be foot clearance for the rear passengers so i would have to look into that a little more
5. other options???
thanks
1. I don't know, since I don't know the actual rating on my sparco belts.
2. Look at the angle of the belt if your mount your belt there. It will be stretched across and where are you going to secure your right shoulder belt?
3. I would still not trust my life mounting my belts on the strut bar, unless you modify the mounts of the strut bar.
4. Do you plan to use the 4 point harness ALL the time? Or just at the track?
5. Just get a harness bar. I can't speak from experience but it doesn't seem very hard to install or to un-install it WHEN you have passengers in the back. But since you might have passenger sometimes your logic behind 1, 2, and 3 don't make sense. So HARNESS BAR....plain and simple.
Modified by sr20power at 8:38 PM 10/11/2009
