For what?teddy wrote:Check the #4 injector.
I'm getting spark, for when I pull the wire. . .it misses. I'll check resistance in the morning and post what I find. There is one thing I'm going to do. I'm pulling the intake manifold and doing this. . http://www.ka-t.org/forums/viewtopic.php?t=3150 and also putting a oil catch can on the PCV valve.180fan wrote:Yes there is something about #4 that needs to be checked soon. Are you getting spark at #4? How is the resistance at injector #4's plug?
Ok, I checked the resistance across the board and got 11 all the way. So what does that mean? That's with the ohm meter set at 200m. I have another KA24DE that came out of a '93 hicus (spelling) and I was looking at the injectors. Two of the injectors had a sticker on them and the bottom tips were different from the others. I stopped in at Napa and asked my bro if they had any instock. They did and the two injectors with the stickers on them are from Napa and they are going to swap them out for me, so I'll have two new one the mix when I do the Mods. It'll be alittle bit becuase I'm in trhe middle of do a B16A swap and full suspension mods on a '94 Delsol, but when I get through with that, I'll do my car and I'll post pics.180fan wrote:That injector is probably stuck slightly open. Check out those resistance numbers across the injector and post.
The catch can is a great idea. You'd be surprised about the amount of stuff it gets. The one thing I'm not too thrilled about with that setup is that filter at the top. That should be routed back to the intake tract.
