4 MAFS later...still can't get past 2500k
luny228
Car: 1996 Nissan 240sx (S14)
pretty much I am pulling out my hair...put in 4 BRAND NEW MAFS in my s14 (KA24DE) and i still can't get past 2500k RPM...
i will tell you this, we tried crossing wires... is it possible for the ECU to fry because of this? Car turns on, AC works etc etc. EVERYHTING WORKS.. Voltage is good too. Mechanic said it was a bad ECU. What do you guys think? It drives, idles fine and all...just the 2500k problem. Thanks
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I think you need to double check your wiring then try an ECU you probably toasted the maf circuit
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Very likely you fried the ecu. Its repairable though.
luny228
oh okay. where would i go to repair it? Sorry, i never dealt with this kind of issue. The wiring is good though. We checked the harness and nothing is wrong. No short circuiting or anything.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Check ECU grounds and MAF grounds.
Add another MAF ground.
Is it getting reference voltage?
luny228
my mechanic pretty much said everything is working the way it's supposed to work. All the wires are good, the harness is good and everything. We tried 4 brand new MAFS. Before when the first MAF went bad, i didn't check the FMS and i accidentally wired it wrong so maybe that was the culprit because the wires did get hot and started to smoke.
luny228
my mechanic already tried to add more ground to the MAF and the ECU grounds are good.
luny228
i opened up the ECU but nothing smells or seems burnt :-/
compactfean
daily
Contact jason at [email protected] he can fix it. And its not ”fried” like the thing actually melts, its just a part in the ecu that shorts out.
luny228
Thank you for your help!
