4 lug wheels on z32...need advice/help
TypeX4Sho
Car: 91 Sil40 96 zenki
hey guys i have a z32 as my daily and i have some racing hart c2 3 piece wheels i want to put on them.....the front bolt pattern is 4x114.3 they are coming off my 240 because its getting a 5 lug for track wheels.... I wanted to know if there is a conversion I can do or where I can find the Adapter spacers they make for the conversion...the only ones i have found were a 2 piece adapter which is good but they were 2 inches wide....now i am looking for an inch wide space increase just like a spacer adapter because of the offset in the front to clear the z32 brakes.....the rear wheels look like they are dual bolt patter and seem to have both 4 and 5 x114.3 patters on them so the rear shouldn't be a problem.... now i know that i shouldn't delete a lug but this is my daily it doesn't see the track or anything so this will purely be for cosmetic purposes because i love these wheels and i don't really want to sell them....any ideas?/??thanks
TypeX4Sho
bump come on guys
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
Racing Hart FTW
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Hmmm, most people are swapping 240 4 lug hubs for our 5 lug hubs. You might be able to nab a set of em really cheap off someone in the S chassis forums. I would think it would be sort of the same concept as swapping to a 5 lug setup from a 4. Maybe do some reading up on this page and get a general idea of what will be involved.
Keep in mind that with a 4 lug setup, the brakes are most likely going to be a lot smaller, and seeing as the Z32 is a very heavy car, there is a good chance of getting uneven wear on the brakes, or even warping just from cruising speeds. Make sure you get a really good set of pads to help to combat this.
TypeX4Sho
well i wouldnt really have to go with a smaller rotor cause they also make the z32 conversion rotor in a 4 lug as well which is what i have on my 240 right now so maybe when i do the conversion to the 240 ill check and see the differences between the 4 lug hub from the s13 and the z32...that would be the best idea if it would convert but yeah ill figure something out...thanks for the advice guys
TypeX4Sho
haha yes your sig just convinced me to do it haha
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
NO!
TypeX4Sho
evildky wrote:NO!
NO! what?
evildky
06 Nissan 350Z GT
just no, do not convert your z to 4 lug to run a specific wheel, just get wheels that fit, the 5x4.5 bolt circle is more common and more available int he propper offset
TTZ32
Car: TT 90 300ZX
[QUOTE=evildky]just no, do not convert your z to 4 lug to run a specific wheel, just get wheels that fit, the 5x4.5 bolt circle is more common and more available int he propper offset[/QUOTEI
I agree
