simmode1 »
https://forums.nicoclub.com/simmode1-u73804.html
Fri Mar 05, 2010 4:47 am
^^^Five lug gives you a wider range of wheels to pick from for whatever your preference is. If you wanna find low offset wheels so you can run stretched tires, theres plenty to pick from out there. If you wanna run relatively high offset wheels so you can use wider tires, lots of those around too.
But with four lug, your chocise are pretty much limited to the wheels I posted above or some much more expensive wheels from the likes of Work or SSR...
If 9.5 inches is wide enough for you, four lug can do that and fit pretty decently wide tires depending on how much fender work you wanna do.
