4 lug to bmw 5 x 120?
Scuffed_ChukiCoupe
Car: Ka-t coupe
Is there any way to do this at all, cause i have a set of breytons no1 is willing to buy that fit bmw's cause they are 17's. They would fit perfect on an s13/14 but the problem is the bolt pattern. Is there any 4 - 5x120 type spacer or conversion or use of hubs from bmw that would work?
Heres a pic btw. They are 235 and 255 wide. I jsut wish i could use them.
Chaluska
the only thing you can do is
1 Buy the spacer/adapter combo, that goes from 4-5 lug
2 Redrill the rotor, and the hub to 5 lug
Scuffed_ChukiCoupe
Car: Ka-t coupe
holy shizz. i never thought about that you know.... that might be able to work.... But i either need extended studs or a way to use bmw lugs they way they are use. You know how vw's and bmws are, there are no studs stickin from the hubs, the lugs are the studs.... but thanks for the thought.
Scuffed_ChukiCoupe
Car: Ka-t coupe
o but now that i thougt about it... would there be enough space left to drill another 5 lug pattern, a wider one at that, on a hub thats already 5 lug?
