4 lug to 5 lug swap
dropem low
Car: 89 240sx,96 maxima,99s10
ok i know this has been ask but cant find it no where so can some one help me i want to do a 4 to 5 lug swap on my 89 240sx but im not sure what all i need. i want to use the 300zx parts if i can so can someone tell me what all i need for this and from what 300zx i can get the pparts from.
thanks for any info
onosqv
Car: '92 240sx Vert
Ok, this is what I "think" is needed. I've been doing lots of reading since I want to convert my front/rear 300zx swap into 5 lug so I can run diff wheels.
Anyway:
5 lug:
1) a. Front hub direct swap for s13 (pdm-racing, rare-trick, gto, attain, etc) b. s14 hub + spindle -> s14 balljoint plugged into s13 lower control arm (pdm-racing)
2) Rear hub - N/A 300zx hub or s14se hub - direct fit -> either buy a new wheel bearing, or you will have to press your old ones out. These are direct fit.
3) Rotors & wheels that are 5 lug (if you have 300zx rotors, then ur set w/ the 5 lug rotors part)
Hope that helps. And if it doesn't -> SEARCH (there's literally hundreds of threads on here, zilvia, and freshalloy)
eddiec
Car: 91 S13
i think all the required info would be over in the Wheel, Tire and Brake forum. in fact i remember someone asking the very same thing. i'd tell you but i dont know. just telling you where it is.
Modifyed
Car: 1989 Nissan 240SX hatchback
I've seen this stuff posted more than a few times but here's guys who actually did it and have pics of it.http://www.nissanperformancema...x.phpRight on. I'm going to attempt at a later date!
Darren
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
Is the primary motivation for this swap generally the fitting of brakes?
People always bring up wheels, but there are SO many bada$$ 4-lug wheels, all the old school JDM stuff. I wish I was 4-lug sometimes just so I could fit Sein Racing or Mk2R SSRs.....
onosqv
Car: '92 240sx Vert
HashiriyaGDB wrote:Is the primary motivation for this swap generally the fitting of brakes?
Well, it does make gettings rotors easier (at least for me). I can't find a machine shop around my area that will return my calls on redrilling 5->4 lug. Of course, I could just not be looking hard enough. I already have a redrilled set, but down the road, it's kind of a pain to get front & rear 300zx rotors and get them redrilled to 4 lug.
Also, yes, there are plenty of wheels for both 4 lug and 5 lug. One of the reasons I want to go 5 lug is that my friend recently stripped one of his studs on a 4 lugger -> that leaves 3 lugs, not to good - but he has still been driving around on it for a couple weeks, haha. So if I had 5 lug -> 4 lugs left, I'm ok for a while.
I think once you get into wide 17's and 18's w/ lower offsets it becomes harder to get 4 lug rims as most companies seem to be favoring 5 lug cars, not that 4 lug is impossible to get. Did you see the custom Work Wheel group buy for 4 and 5 lug on zilvia - mmmmmm, sexy, starts at @2K shipped, .
All of these reasons are not real "needs"... but neither is the 300zx brake swap and 5 lug swap itself :-D.
nismofly
Car: 89 Nissan 240SX Hatch
at the same time i wish i was 5 lug, i want gram lights 57f's, they only come in 5 lug
oh by the way, Ryan's site rock your socks, heres what youre looking for...
http://www.sillbeer.com/5lugswap.php
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
On the subject of rear hub bearings, just find a set of hubs with the bearings on them, makes things way easier and convinent. The set I have on now has over 190,000 miles on them and they dont make a sound, not bad for $40.
Oh and the reason they specifie NA 300zx rear hubs is because the TT version has the integral drum brake. If you get the whole twin turbo 300zx rear brake assembly it bolts onto the 240sx knuckles, e-brake and all. Its just you either have to decide NA hubs and stock brakes, or TT hubs and go through the hasle of swapping all the other junk on (not easy).
