4 lug fno1rc 18x8F 18x8.5R...what size tires? any pics?
240on430
Car: 1993 240SX SE
I have tein s-techs. The seller thinks the offset is +4. He's selling them with 225/40 tires all around.
Pics of 18s with the same or similiar sized wheels would be really helpful.
Modified by 240on430 at 7:53 PM 10/9/2006
whiterps13
Car: white LE hatch
Unless they are one off customs, I doubt they are +4.
The most extreme 4 lug sized FN's are 17x9 +20.
naed240sx
Car: .....
whiterps13 wrote:Unless they are one off customs, I doubt they are +4.
They don't even make the 18s in 4 lug.
Edit: I lied. There are actually 4 lug 18" FN's. They certainly aren't +4 though.
240on430
Car: 1993 240SX SE
I didn't think they were +4. They're probably around a +30 from what he tells me. He said they didn't tub with his s-techs or slammed with coilovers.
240on430
Car: 1993 240SX SE
any pics of these wheels though?
naed240sx
Car: .....
Dude, FN's are one of the most popular wheels out there. Use ****ing GOOGLE.
Sorry if this sounds harsh, but you are being lazy.
240on430
Car: 1993 240SX SE
turns out they are 18X7.5s all the way around. I'm still not sure of the offset though.
240on430
Car: 1993 240SX SE
I just installed the wheels and I think I need hubcentriuc rings because the front shakes at high speeds. It didn't shake with stock wheels.
Would rings get rid of any play? Poly or metal?
I looked at the FAQs but couldn't fund anything about tuner lugs.
Do I NEED tuner lugs?
thanks!
naed240sx
Car: .....
Get hubcentric rings from http://www.splparts.com.
If you are good at tightening down the lugs properly with the car off the ground, you don't need them though.
240on430
Car: 1993 240SX SE
how about aftermarket lugs? should i get them?
naed240sx
Car: .....
only if you can't use your stock ones.
240on430
Car: 1993 240SX SE
...as in if they're broken?
I've seen some sites that sell wheels and they say you that some wheels require aftermarket lugs.
naed240sx
Car: .....
some wheels require aftermarket lugs because the stock lug wrench won't fit down into the holes of the wheel. Aftermarket lugs have included deep sockets that will fit easily into the holes.
hannibal
Car: Red Line to Glenmont
The only 4 lug 18x7.5 FN's come width a +42 offset. Make sure youre not rubbing anywhere. These sit really close to the strut.http://www.5zigenusa.com/produ....html
