4 lug brake upgrade
wilfonzo
Car: s14
is there anyway to upgrade the brakes without going to five lug, i like my rims too much to switch to five.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
You can fit 300zx brakes without a problem you just have to have the rotors drilled out by a machine shop for your lug pattern. It usually costs $25 per rotor.
usdm_180sx
Car: 1993 Nissan 240SX base S13
If you go with the 300zx brakes just make sure that your wheels have enough backspacing so that the 300zx brakes will fit. If they don't fit you can use a 5mm spacer. Anything more than a 5mm spacer you will need longer wheel studs.
Another (cheaper) alternative is to go 180sx brakes. These fit inside the stock s13 wheels so they will fit inside your rims.
virus77
Car: 95 S14, 71 240z, 97 e320
Also if you are not really tracking the car look into a good set of pads and stainless lines and it might offer the performance gain you are looking for. Bigger brakes just means less brake fade from repeated use.
wilfonzo
Car: s14
i have a +35 offset will that be enough for the 300zx brakes
virus77
how close are your spokes to your calipers right now, offset doesnt have too much to do with caliper fitment. How big are the rims and how wide?
wilfonzo
Car: s14
not very close at all my rims make my brakes look retarded, i have the 5zigen fn10r-c 17x8 +35, the brakes look rediculously small
nopaintsls
Car: 91 fastback!
will fit with no problems... I have the same setup as you same wheels 2
wilfonzo
Car: s14
some nice wheels, how do they look with some real brakes in them
virus77
Yeah, the cheapest and best looking route would be to get z32 brakes and get the rotors redrilled to 4 lug.
wilfonzo
Car: s14
id like to compliment you on your beautiful s14, if i were to own an s14 id want it to look like that
virus77
Thanks alot buddy
