# 4 Cylinder
peckernat
Why is the # 4 or back cylinder higher then the rest. I just purchased a 1993 240 SX conv with 61k on it and went to change the plugs and saw the back cylinder plug wire was sitting about a 1" higher then the rest. After removing all plug wires and looking at the plugs, the back plug does sit higher then the other 3, Why
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
pull on the wire while pushing down on the spark plug wire tube, the wire is just holding the tube up a little.
peckernat
This does not explain why the plug sits higher then the other 3 cylinders.
