Sonikfuri wrote:Hey guys, I finally got the balls up to start working on my car (I figured after dreaming about it so often I might as well)...So I did a compression test got 125 150 125 0. So I took off the valve cover and checked the rocker arm bolts and found out that one of the #4 cylinder bolts is stripped, so tomorrow I'm going to helicoil it. After that I'm going to do another compression test and then check to see if she's getting fuel.
-Any other suggestions, and other than just taking out the fuel injector and cranking it how do i check to make sure that fuel injector is gettin fuel?
Thanks guys.
Before you go about all that trouble, 125 is a very low compression number. When you're doing the compression test, you depress the gas pedal all the way, right? If you got 125 using the correct procedures then it sounds like that motor needs rings/rebuild.
