wkobe88822 wrote:Hi i Have a 01 I30 and I just got 4 codes kind of weird P0135,141,155,161 seems weird and both bank 2 sensor are about a month old any ideas would be great.
Wayne
P0135 heater element is shot
P0141 heater element is shot
P0155 same as P0135
P0161 same as P0141
It's basically saying that ALL 4 sensors are shot simultaneously. This is not the case. In fact there was a TSB for this, the Nissan Xterra had this same EXACT issue. I strongly suspect that if nothing else it is simply a matter of unplugging and reconnecting the O2 sensors AND while you are there, taking a good look at any ground wires running off of the sensors. I dug up this link. I hope it helps.
http://x.nissanhelp.com/forums/xterra/8 ... d-bad.html
It's a rather unusual thing to experience, however I'vee seen this happen before sometimes because the plug wasn't secured and it wiggled loose while driving, resulting in bad mileage before I realized I had a disconnected O2.
