Peabody »
https://forums.nicoclub.com/peabody-u10351.html
Tue Feb 16, 2010 6:15 pm
OK, I do not know what to do. This started after I had a NEW Jasper KA24E installed after my original KA locked up. I am the original owner and have never had any problems with clutches before the new motor.
I had a ACT EXTREME before the motor blew and it was to stiff for me, I have a ruptured disk and have leg issues. SO I had a ACT HD installed with the new motor. It was softer in the beginning but after time was firmer then the extreme. I drove it maybe 600 miles and then it would not go into gear. The TOB was melted onto the teeth and made an indention on the TOB where the teeth of the PP were. The PP was scorched up but the clutch itself was not worn out.
So I tried a Exedy Stage 1 and this thing was much stiffer then the ACT and it make a sound like the reverse sound in any gear and would get louder with higher RPM's. The clutch was also very notchy pressing in or out and got worst with more millage. After maybe 250 miles the clutch assembly came unbolted from the top from the hard force of pushing in the clutch.
Still Idiot me took it to the same shop because they were charging me $200 for the labor. They thought the trans output or maybe input shaft (I FORGOT) could be bad because I would hear a bearing whine when the clutch was out and as I pushed down on it the whine would go away.
After spending $800 for a new 5 speed and installing a RSD clutch everything was fine for about 2 weeks. When I would 1st drive the car in the AM it was fine and after maybe 10 miles the pedal would stiffen up a little and was notchy on release. The odd thing is if I turned the motor off the clutch if light as a feather and as smooth as silk. It only acts up with the motor running. I just drove it and noticed that the time it took to act up went from 10 miles to 8 then 6, ETC. Now it is stiff at 1st start and very notchy, sticky pedal going down and up. It is like you have no control, the clutch is either engaged or not.
I have changed all lines, fork, master & slave at least 2 times and even the Damper that is between the master and slave on 89 and 90 models. Most people bypass this and when I did then the clutches were acting MUCH stiffer and more notchy.
But only with the engine running the pedal is like this. I even can feel the pedal starting to stiff up when I bump the started.
I was thinking maybe the Flywheel is warped! This is the only part not changed. I think the idiots only had it turned 1 or 2 times.
The Jasper engine is under warranty and the Rep said the crank could be a problem and they want to check this with a run out gauge at a different shop. But that shop is very expensive and if the engine is fine then I will have to pay for another clutch job at $100 an hour.
My friend said he would do it for $300 & I could buy a new flywheel and try another RDS clutch. That clutch was great for me, I want a clutch that will catch 2nd but have a soft pedal. It is 15% more clamping over stock. I only have a header, performance Chip, Air Intake and exhaust.
Would a Bad flywheel eat up TOB & make the clutch act like this?
