4.6l police interceptor swap.
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
greengt2nv
Car: 91 s13 hatch w/super hicas 305 v8 (Under constuction) 99 yzf 600R
ok i need someones help on this. Im getting 4.6 out of a crown vic and going to put a 5 speed on it.... anyway what all has to be done as far as getting it to fit? can i use the 240's drive shaft? etc...
greengt2nv
i guess im on my own with this one...
240cp
Car: 95 240sx
Killernoodle has started a 4.6 swap about 10 threads down. Hit him up on what needs to be done.
wrxratd
Car: 1990 240sx hatch, 2002 WRX
Custom custom and more custom... Hope you're comfortable with your fabrication and wiring skills. Sounds like a fun package though. What 5 speed will you be using? t-3650?
Mr. S13
Car: 90 240sx
greengt2nv wrote:ok i need someones help on this. Im getting 4.6 out of a crown vic and going to put a 5 speed on it.... anyway what all has to be done as far as getting it to fit? can i use the 240's drive shaft? etc...
please for the love of god tell me your going to throw those 2valve heads in the bushes...
WDRacing
If I were going to use a 4.6 I'd use the all alum version in the Mark VIII or whatever model Mustang they came in. But the Marks are cheap.
Mr. S13
Car: 90 240sx
Sn95 cobras had the alum 4valve 4.6 the problem is that the people with those motors want way too much for them. However honestly if you really work at it you can get those pi heads to flow a little air. Plus the iron block motors are a lot cheaper, parts wise as well as initial cost. Good luck to you sir no matter which way you choose to go.
WDRacing wrote:If I were going to use a 4.6 I'd use the all alum version in the Mark VIII or whatever model Mustang they came in. But the Marks are cheap.
WDRacing
Oh I won't be doing a swap anytime soon. If I did I'd use a regular SBC 350 or a Ford 302. I'm a big fan of cheap used and new parts. You simply can't beat the old Ford and Chevy motors for that. Add a really cheap single turbo and you can make a reliable 420 hp daily driver that makes over 300 ft lbs of torque by 2700 rpm all while keeping the stock EFI or TBI that it comes with.
That would be my recipe
Return to “Hybrids”
