pushrods ftwOutToWinPAHC wrote:Those modular V8 are VERY wide. I just saw one side by side to an LS1 on stands. I dont think it would work, unless you relocated the steering column to rack bar
I sold both my mark viiis to buy my s13...weird. never thought i would see them on nico club. and its not the EXACT same. different intake manifold. hahabball212000 wrote:it will fit i believe by all the measurements i have taken at work. but then again those dont mean anything when it comes to actually going into a diff. car. but canton does make front sump oil pans for the 4.6 dohc. if you want to try it buy a long block out of a lincoln mark 8 as it has the same mount locations and is almost exactly the same and is alot cheaper than a cobra engine. of course i know that not one person will ever do this.maybe i should try? hmm....
They are both ford engines in that picture. Left motor is dual cam cobra...and the other is the 302 sohc.OutToWinPAHC wrote:Those modular V8 are VERY wide. I just saw one side by side to an LS1 on stands. I dont think it would work, unless you relocated the steering column to rack bar
Example a LS1 or SBC is similar to the 302
Dude just count the cams on that side by side pic I posted you can clearly see 4offroadbob wrote:No, that's definitely a push rod engineford yes
I was wrong yet...the one on the right is not a ford engine that is an ls1 look at the heads, def. ls1. The picture is labeled wrong. The one on the right is the cobra 4.6l and the right is a 350 cu ls1.blacksrjdm wrote:
that's a certified p.o.s. is what that is... four turbos? laaaaaameJessy240sx wrote:
what about this
Modified by Jessy240sx at 1:21 PM 10/27/2008
