4.4 rear end and speedometer calibration 95 240sx
karmakaze
Car: 98 240sx SE
i have a 95 240sx and a s13 VLSD/axles with the 4.4 ring gear that i am about to install.
this will set my speedometer off by about 6.0% so, should i go about recalibrating my speedometer? and how do i go about doing that? or am i better off with an Apexi Rev/Speed meter?
i know where and how to take the voltage reading, but i can not find much on how to do a calibration.
is there a pot on the back of the gauge cluster?
180fan
Car: 89 fastback
you got it. It's on the back of the speedo.
karmakaze
Car: 98 240sx SE
180fan wrote:you got it. It's on the back of the speedo.
what is the range? 1 to 5 volts? and is that scaled 0-120mph?
so do i just use a voltage generator and turn the pot until the speed reads 6% higher?
Modified by karmakaze at 4:49 PM 3/12/2006
