4:1 header
00_Altima MD
Car: 2004 Sentra SE-R Spec V
I just recently bought a stillen 4:1 header for my 2000 nissan altima gxe and my check engine light came on. Is there any way that i can get that to go off and if not then will i be able to pass emissions in indiana.
ninjak84
Car: S13, Z32, Titan
You should still be able to pass emissions. As for the engine light, try asking your dealor why it would happen.Sounds like a fairly common problem, I've heard of others who've had the same problem with their Stillen Altima headers.
00_Altima MD
Thanks alot...I think the reason that it might be doing that is because the cat on the stock manifold is right on the header. do you think that could have caused the light to come on, b/c the computer thinks that it has no cat and is reading the air wrong or something, because there are 2 sensors that are plugged into the header itself.
