mac ,Keep it waxed - it really does "slip through the air better " , keep tire pressure(cold) additional 3 psi +from placard ,better - next set of Low Rolling Resistance tires (BUT they're the "flimsyest" ! ) ,Max diameter tires , Clean Hi-flow A/Filt., routinely blast clean MAF , if a premium fuel requirement - use it ,you can drive "briskly" just don't drive Flaky - gas,brake,gas,brake,brake,floored,brake,gas,brake ,floooooored ......know what I mean? Get up to speed AHEAD of everybody and then keeping a "light-cruise" ,fun & the way to go.If base timing is adjustable some expert "play"here can improve response AND mileage significantly (gotta def. keep to prem. gas here).The obvious rolled down windows IS supposed to increase "drag" ,the more complex = exotic sparkplugs ( just don't go too far on a "stock" set)."Wives tale" leave gas filter a little clogged cause it will save fuel ??
You Gotta brake for animals - What did I leave out ??
