4.08 gears for Q45
Mark86T
Car: 96 Q45, 86 Z31T, 01 Ford Ranger, 77 280z
Isn't the Z32TT diff the same unit as the Q? It has 4.08 gearing if I'm not mistaken. Wouldn't that make it a bolt in swap?
MiniMan
Q45tech
4.083 is the diff gear for the automatic 300zx non turbo as Nissan V6 needs to turn 15% higher than V8 at cruise to create enough torque for smoothness [non lugging at 50 mph AC on up normal inclines]. R200 [Q] and R230 diffs [TT] are quite different
1992Q45A
Just do yourself a favor, and pick up the BRM 4.08.. If you want to do the swap, that is.
Way back in 2002 the zx diff swap was looked at, considered, and then dumped.
Those axle stubs are the real bugaboo in the equation. Embarassing now that it took me almost a year to figure it out. :(
Mark, if you can locate a "donor" Q45 rearend, it's a simple matter of $850 plus shipping.
Corey, where's that sig pic from?
Mark86T
So it's difficult to swap from the Z32? That $850 price for the 4.08 has me thinking that the work to swap the Z32 diff might be worth it. They are much cheaper. I need to remove my rear member to replace a leaking subframe bushing (hence ALL the bushings) now so it will be out of the car anyway. I guess I'll have to see what I can get a Z32 N/A diff for. My TT friends have already done the TT to N/A swap in their cars.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hmmm...always better to buy a wheel that rolls and will bolt on than to reinvent it. Experience is education gained dearly.
Mark86T
True, very true.
1992Q45A
Trust me...................................
If greg could have made it worked, he would of. He doesn't like spending any more money then absolutely neccasary, when it comes to aftermarket parts. You can rest assured this has been looked at, and deemed not worth it.
$850 is a kick a$$ price. Stillen sold it for over $2,500 for over 10 years...
Mark86T
Ok, I did a search on this & didn't find out exactly what I get for the $850. If someone could take the time to gimmie a list I'd appreciate it. Thanks. Mark
Rex
Car: None
Use the link in my sig to upload/post full size pics.
The 4.08 info.
1992Q45A wrote:Trust me...................................
You callin' me cheap?
If so, you're right on. :D
Mark - For $850, you get a complete teardown and reassembly of your donor rearend, including Nissan ring and pinion, a custom-fabricated spacer (which cannot be bought anywhere else), special hardened longer bolts and all new seals.
Call around and inquire as to a ring & pinion swap (without any modifications or custom parts) and you'll see this is a fair price.
Shipping to CA is on you as well, I may be able to help out with return shipping.
BTW, it's not a money-maker for me or BRM... If I sell 6 I will recoup my initial costs, if I sell 10 I'll have enough to pay for the 4.08 I bought for myself...
1992Q45A
When it comes to the Q anything under 1,000 that has decent gains is a bargin!
MiniMan
AZhitman wrote:Corey, where's that sig pic from?
It's the AeroPalace body kit on a 90-96 Q! Gad I love the looks of that thing... nicest kit I've set my eyes on.
Corey
Love it.
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Greg, how many have you sold?
You bought cores, right?
If so, any low mileage cores in the bunch?
1992Q45A
I have a low mileage 92 core.. will be here in a month max..
Mark86T
Thanks I appreciate the info. It is a bargain. I didn't realize that someone else is doing the bulk of the work.
HD - I have a couple in the "punkin pile" that have approx 60K on them. Only sold 2 thus far, and one is mine. :)
Keep in mind mileage won't matter much as all wear surfaces and seals are being replaced.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
1992Q45A wrote:T$850 is a kick a$$ price. Stillen sold it for over $2,500 for over 10 years...
Actually, I think that was just the ring and pinion gears. The purchaser still had to pay for installation.
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
AZhitman wrote:HD - I have a couple in the "punkin pile" that have approx 60K on them. Only sold 2 thus far, and one is mine. :)
That's cool, I understand what you're saying, but I'm hesitant to have a set of gears only (pinion bearing, etc, etc) installed in mine, with possible other issues in it.
Are any of them verified 90 or 91 *only* non TCS, non A, T (if the A, T, etc matters, I don't know but would rather not take any chances)
Thanks man,
I can check...
I can't imagine one having ANY issues that wouldn't be resolved by this rebuild.
