I found this out this weekend. I was unable to transfer the contact list, and it doesn't charge the Iphone either. It's actually a pretty useless connector for me now.b117sat wrote:If you look at this link: http://www.nissanusa.com/bluetooth/index.html you'll note on the chart that you can't transfer your phonebook. The only alternative is to manually input all the names and numbers. In fact none of the iPhones can transfer the phonebook. I suspect its probably apple crippling the bluetooth. Anyway, I hope it helps. If you have questions, I have an iPhone 3GS.
