The pinch weld area is pretty strong, the puck/wood block from my floor jack has bent it out of shape from using that spot or around it since I try to use the pinch weld for my stands. I just use steel epoxy putty to strengthen up the area again. But it took many, many, years to bend that area out of shape.
Once on my slightly slanted driveway, the wooden block slipped off while using rear jack point 4, and the rogue fell on the damn jack and slightly bent my muffler.
Fortunately, I didn't puncture it.
My 2 cents.
