pm_page6776 »
https://forums.nicoclub.com/pm-page6776-u103215.html
Sun Oct 19, 2008 4:32 pm
Sorry, 3rd gen does not come with cap, rotor, and wires. Furthermore worn plugs should not cause your fuel mileage to drop that much, if they did you would feel the engine missing at idle. If you only went 60 miles on 3/4 a tank, you more likely have a fuel leak or a transmission issue. Is your service engine soon light on? If the light is on it could indicate an issue with your fuel metering causing poor mileage. Plugs are due at 105,000 miles so I would change them, but I would not expect a huge gain in mpg.
