3rd Gen Brake Lights Wont Light Up...Please Help
dadismanc3110
Car: 92 maxima gxe pear whitel in color
Hello everyone. The light bulbs are brand new and the tail lights work fine. I found a tail lamp fuse in the dash fuse panel and its a good 10 a fuse. Non of the three brakelights light up when I depress the pedal. Im not sure what to do next. Any advice would be greatly appreciated. :facepalm:
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
There is a brake switch activated by the brake pedal
The stem of the switch may not be extended completely for it to turn on
On the 4th gen you can adjust this easily by changing the distance
between the brake pedal and the switch
dadismanc3110
Do you know what this switch looks like and exactly where it is located? I tried to find it by following the pedal and pedal arm as far up as I can see and I dont see anything. Ive used a flashlight and looked on you tube and cant make any distinction. Thanks alot.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
It's mounted on the bracket that the pedal hinges on and mounts to. Here's a picture:
NutriaforBreakfast
thanks Mr Minister
Note one of the switches is for the "cruise control" or the ASCD
So be sure to adjust the correct one
Has anyone ever adjusted the ASCD switch?
