I've got a 93 Maxima SE with a VE30de in it. I'd like to swap to a manual transmission. Do i need to swap ECU's or harnesses or anything when doing this swap? I believe the ECU needs a signal for a neutral switch? can i just supply power or ground to that pin on an Auto ecu?
Thanks very much.
