3rd gen altima 20inch rims
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
TheBoyWithTheAlti
Car: 06 nissan altima 2.5s
my carImage
-I have a 06 Nissan altima 2.5s bone stock.
- The factory rims on there are 16x7 with 215/60-16.
-The rims i have on order are chrome 5 poke 20x8.5, et +35Image
-Whats a good tire size that will not rub with out modifications???!!!! Some rim shops recommend 225/35-20 and some 245/35-20
will the offset look good on this car, any with pictures of this setup??
HELPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP
v9806180
Car: 02 Altima
I've got 20×8.5+40 with 245/35s and the rear rubbed just a little bit when i turn cause I dropped it. With the +35 offset you will poke out and have to go with that 225 and if you drop it you're also going to need to roll your quarter panel's.
TheBoyWithTheAlti
Thanks for the information I'm probably going to go with 225/35-20 because i dont plan on dropping at all i don't want to rub,so 225 it it. Also how is the ride quality with 20s?
v9806180
Car: 02 Altima
A little rougher but not that bad. But in your case it might be a lot rougher cause your stretching the tire.
TheBoyWithTheAlti
Before the last time we spoke i just changed my mine getting the same ones just in a +45 offset i over looked all the choices and just going to stick with the 245/35 looks beefy rides better all thumbs up !!!
Return to “3rd Generation Altima Sedan (2002-2006)”
